[fusion-users] Overview Map
Kori Maleski kori.maleski at gmail.com
Wed Mar 17 16:47:36 EDT 2010
I have had the same issue.
On line 110 of OverviewMap.js, add the following 2 lines:
        this.mapObject.projection = this.getMap().oMapOL.getProjection()
        this.mapObject.oLayerOL.projection =
That will workaround the projection issue.  Haven't fully tested - may need
further tweaking.
Cheers,
Kori Maleski
On Wed, Mar 17, 2010 at 12:53 PM, Mark Pendergraft <markp at meadgilman.com>wrote:
> I'm having a problem with the overview map not displaying properly when I
> have a coordinate system other than LL84 defined for my map.  The overview
> map seems to have the wrong coordinate system attached to it, which throws
> off the scale of the overview map and also causes the red rectangle not to
> show up.
> Previously I had an issue with my map not displaying properly (being zoomed
> out too far, units didn't correspond to my map, etc.) which was resolved by
> adding a <ProjectionCode> and <ProjectionDef> to the Map element.  However
> the Overview Map still behaves in the same fashion that the map did prior
> to
> adjusting the above settings.  I think the Overview Map is still trying to
> display my map, which is in EPSG:2926 in the default projection EPSG:4326
> Is anyone else experiencing this issue?  And has anyone come up with a
> workaround that doesn't involve a reprojected copy of the same map?
> Thanks.
> -Mark P.
> http://n2.nabble.com/Overview-Map-tp4752630p4752630.html
> Sent from the Fusion Users mailing list archive at Nabble.com.
> fusion-users mailing list
> fusion-users at lists.osgeo.org
> http://lists.osgeo.org/mailman/listinfo/fusion-users
URL: http://lists.osgeo.org/pipermail/fusion-users/attachments/20100317/56cdae8a/attachment.html
More information about the fusion-users mailing list
