[fusion-users] Map. Runtime vs. Permanent
miansi AndreiSinelnikov at SierraSystems.com
Fri May 7 19:15:22 EDT 2010
Hello,
I am little bit confused about ho maps being handled in Fusion.
In AJAX Viewer world I used to modify resources (map, layers...) either
permanently using ResourceIdentifier like this:
Library://Samples/Sheboygan/Maps/Sheboygan.MapDefinition
or temporarily. Using ResourceIdentifier like this:
String.Format(@"Session:{0}//{1}.{2}", sessionId, mapName,
MgResourceType.MapDefinition)
In Fusion, as far as I understand, there is no such concept as runtime vs.
permanent map. Map always should be referenced as Session:<session id from
map widget>//<map name from map widget>.MgResourceType.Map
Am I correct?
How can I implement same functionality I had in my AJAX Viewer (temporarily
layers)?
Thank you,
Andrei
View this message in context: http://osgeo-org.1803224.n2.nabble.com/Map-Runtime-vs-Permanent-tp5021743p5021743.html
Sent from the Fusion Users mailing list archive at Nabble.com.
More information about the fusion-users mailing list
