[fusion-users] I do not recognize "Fusion" in my application: "Fusion is not defined"
Fixi apcr at tragsa.es
Fri May 14 06:46:40 EDT 2010
Hello,
I have this code to add a layer to my map:
function refrescaMapa()
	var map = Fusion.getMapByIndice(0);
	var url = PM_XAJAX_LOCATION + 'refrescaMapa.php';
	var params = {
		mapname: map._sMapname,
		session: map.getSessionID()
	var options = {
		onSuccess: OpenLayers.Function.bind(map.reloadMap, map),
		parameters: params
	Fusion.ajaxRequest(url, options);
The problem is that it recognizes "Fusion" and the browser returns me the
following javascript error:
What do I have to do to make me acknowledge the use of Fusion Framework?.
The previous code I have it added the  "javascript/src/xmlhttp.js".
Help, please.
View this message in context: http://osgeo-org.1803224.n2.nabble.com/I-do-not-recognize-Fusion-in-my-application-Fusion-is-not-defined-tp5050396p5050396.html
Sent from the Fusion Users mailing list archive at Nabble.com.
More information about the fusion-users mailing list
