[fusion-users] Re: ubuntu 10 php 5.3 issues
jbogdani jbogdani at gmail.com
Tue May 18 08:35:56 EDT 2010
Thank you for your reply!
I did solve this issue!
Just a question: is there any tutorial for configuring Fusion to log errors?
It would be quite usefull.
Mapserver was working good. I tested it outside Fusion and the mapfile is
correctly parsed and the map is correctly shown.
Here is the error log of firebug:
Fusion Error: WARNING: Exception occurred in AJAX callback. Message: illegal
XML character Location:
http://localhost/webgis/fusion/MapServer/MapServer.js (138) Response: FATAL
ERROR: Session save path () doesn't exist or is not writable
(location: http://localhost/webgis/fusion/MapServer/php/CreateSession.php)
It seemed it was permission problem. I checked my phpini conf and found:
session.save_path: no value!
It was strange! changed the value of session.save_path in php.ini, restared
apache, and everything works fine now!
Thank you
View this message in context: http://osgeo-org.1803224.n2.nabble.com/ubuntu-10-php-5-3-issues-tp5069084p5069744.html
Sent from the Fusion Users mailing list archive at Nabble.com.
More information about the fusion-users mailing list
