[fusion-users] Re: No properties shown in selection
Zac Spitzer zac.spitzer at gmail.com
Thu Nov 18 17:40:21 EST 2010
can you submit a patch to trac?
On Thu, Nov 18, 2010 at 11:25 PM, gnoviello <grazia.noviello at libero.it> wrote:
> I found the solution in GetPropertiesSelected.php file.
> At load map time, in the LoadMap.php file, an array of properties of the
> existing layers is stored in a session variable "property_mapping". In the
> GetPropertiesSelected.php file, that reads the properties of selected item
> on map, this array of properties is read.
> I've inserted a new layer in map after the map is loaded, so when I
> requested the selected object on this new layer, for this layer there wasn't
> an entry in the session array "property_mapping".
> So for my new layer no properties was requested to the service.
> Now I've modified the GetSelectedProperties.php file to read, if there
> aren't, the properties list of new layer.
> It works.
> Thanks,
> Grazia
> View this message in context: http://osgeo-org.1803224.n2.nabble.com/No-properties-shown-in-selection-tp5750730p5751435.html
> Sent from the Fusion Users mailing list archive at Nabble.com.
> fusion-users mailing list
> fusion-users at lists.osgeo.org
> http://lists.osgeo.org/mailman/listinfo/fusion-users
Zac Spitzer
Solution Architect / Director
Ennoble Consultancy Australia
http://www.ennoble.com.au
http://zacster.blogspot.com
+61 405 847 168
More information about the fusion-users mailing list
