[fusion-users] Re: Vector editing with Fusion
Jackie Ng
jumpinjackie at gmail.com
Tue Mar 8 05:06:48 EST 2011
The fusion map widget wraps around the OpenLayers map, which is accessible
through its oMapOL property. From there you can do anything that you can
normally do with an OpenLayers map object.
As for vector snapping, I do not believe it is possible because the
OpenLayers.Layer.MapGuide is a grid-based layer and not a vector-based one,
hence there's nothing to snap to.
- Jackie
View this message in context: http://osgeo-org.1803224.n2.nabble.com/Vector-editing-with-Fusion-tp6088339p6118708.html
Sent from the Fusion Users mailing list archive at Nabble.com.
More information about the fusion-users
