[fusion-users] Re: selection problems
Paul Spencer
pagameba at gmail.com
Mon Nov 14 13:22:42 EST 2011
By default, I think Fusion's php backend tries to dynamically load php_mapscript using the dl function (in Layers/MapServer/php/Common.php). Recent versions of PHP have deprecated dynamic loading of modules and the default configuration is to require they be loaded via php.ini. I never did look into whether this was configurable or not, it might be a setting in php.ini to enable the dl function.
Cheers
Paul
On 2011-11-14, at 12:34 PM, jbogdani wrote:
> Hello,
> I solved the problem, and it is not a Fusion or mapserver problem. It was
> (in my case) a mapscript problem. When you install mapscript on a unix
> server you should load manually the php_mapscript.so extension in php.ini. I
> didn't know this and this was the cause of my problem (mapscript was not
> working at all).
> I added the extension in php.ini, restarted Apache, and Fusion workes now
> like a charm!!
> View this message in context: http://osgeo-org.1803224.n2.nabble.com/selection-problems-tp5186819p6993367.html
> Sent from the Fusion Users mailing list archive at Nabble.com.
> fusion-users mailing list
> fusion-users at lists.osgeo.org
> http://lists.osgeo.org/mailman/listinfo/fusion-users
More information about the fusion-users
