[fusion-users] Unable to display map using fusion
Michael Adair madair at dmsolutions.ca
Mon Apr 9 12:29:59 EDT 2012
Hi
As Zac said, you should start by getting the 2.2 release and use that.
Beyond that, those errors sound like the LoadMap call isn't reading your
map file properly, I would check the path, make sure it's readable, etc.
Mike
On 09/04/2012 3:30 AM, badrul wrote:
> Hi
> I have recently started working on GIS stuff, i have created mapfiles and
> for displaying them i am using fusion as an interface. I have modified
> ApplicationData.xml and updated<MapFile>  tag with path where my mapfile is
> saved on my computer, but the problem is its not displaying any map, i
> checked error file and it contains following:
> [Mon Apr 09 12:30:15 2012] [error] [client 127.0.0.1]   thrown in
> C:\\ms4w\\apps\\fusion\\MapServer\\php\\LoadMap.php on line 129, referer:
> http://localhost/fusion/templates/mapserver/standard/index.html
> [Mon Apr 09 12:30:16 2012] [error] [client 127.0.0.1] PHP Fatal error:
> Uncaught exception 'MapScriptException' with message 'Property 'imagetype'
> does not exist in this object.' in
> C:\\ms4w\\apps\\fusion\\MapServer\\php\\LoadMap.php:129, referer:
> [Mon Apr 09 12:30:16 2012] [error] [client 127.0.0.1] Stack trace:, referer:
> [Mon Apr 09 12:30:16 2012] [error] [client 127.0.0.1] #0
> C:\\ms4w\\apps\\fusion\\MapServer\\php\\LoadMap.php(129):
> mapObj->__get('imagetype'), referer:
> [Mon Apr 09 12:30:16 2012] [error] [client 127.0.0.1] #1 {main}, referer:
> [Mon Apr 09 12:30:16 2012] [error] [client 127.0.0.1]   thrown in
> I have been stuck with this problem for a week now, i am feeling totally
> clueless about how to proceed, any help from your side will be apreciated.
> Thanks&  Regards
> Badrul
> View this message in context: http://osgeo-org.1560.n6.nabble.com/Unable-to-display-map-using-fusion-tp4715312p4715312.html
> Sent from the Fusion Users mailing list archive at Nabble.com.
> fusion-users mailing list
> fusion-users at lists.osgeo.org
> http://lists.osgeo.org/mailman/listinfo/fusion-users
More information about the fusion-users mailing list
