[fusion-users] website issues
Jonathan Moules jonathanmoules at warwickshire.gov.uk
Fri Jun 8 03:08:07 PDT 2012
I'm investigating web mapping clients (based on -
http://geotux.tuxfamily.org/index.php/en/component/k2/item/291-comparacion-clientes-web-v6
and fusion looked quite interesting. However I came across several issues:
a) There is nothing in the gallery, it says "coming soon". The history says
its been saying that for 4 years!
b) The nabble links from - http://trac.osgeo.org/fusion/wiki/MailingLists -
both lead to 410's (deleted forums).
c) The geotux comparison says "It has commercial support.", however I can
see no reference to this anywhere on the Fusion page or the FAQ. Does it?
d) The big "trac" in the top left points to example.com.
Just figured the project may wish to address these issues.
Jonathan
This transmission is intended for the named addressee(s) only and may contain sensitive or protectively marked material up to RESTRICTED and should be handled accordingly. Unless you are the named addressee (or authorised to receive it for the addressee) you may not copy or use it, or disclose it to anyone else. If you have received this transmission in error please notify the sender immediately. All email traffic sent to or from us,  including without limitation all GCSX traffic, may be subject to recording and/or monitoring in accordance with relevant legislation.
URL: <http://lists.osgeo.org/pipermail/fusion-users/attachments/20120608/75c5b0c7/attachment.html>
More information about the fusion-users mailing list
