[fusion-users] Database Entry Form
Rachot Moragraan moo at ci.garden-grove.ca.us
Mon Jun 11 17:18:16 PDT 2012
James,
Probably the easiest thing I can think of is to use the InvokeURL tool. Open your layout and add that button somewhere in your toolbar.
Then i think Gordon did a good job of answering the rest here:
http://forums.autodesk.com/t5/Autodesk-MapGuide-Enterprise/Does-InvokeURL-work-in-Flexible-Fusion-layouts/td-p/2582570
>From there, once you have the keys on the selection, you can query your PostGIS for the data and present a form. Then it's all PHP and PostGIS from there. (assuming you're using php).
Hope that helps!
----- Original Message -----
To: fusion-users at lists.osgeo.org
Sent: Monday, June 11, 2012 4:38:00 PM
Subject: [fusion-users] Database Entry Form
Hi All,
I’m looking to create a form to update, delete and create entries in a
PostGIS enabled DB.  The layer that I want to update is being displayed by
mapguide.
Currently I’m doing this on a separate form outside of mapguide, but I want
to do this within mapguide now.
I’m relatively new to mapguide and fusion so my question is how difficult
would it be to modify the selection widget to allow changes to the records
it pulls.
Thanks!
James Banting
M.Sc Student
Department of Geography
University of Lethbridge
4401 University Drive
Lethbridge, Alberta, T1K 3M4
View this message in context: http://osgeo-org.1560.n6.nabble.com/Database-Entry-Form-tp4980592.html
Sent from the Fusion Users mailing list archive at Nabble.com.
fusion-users mailing list
http://lists.osgeo.org/mailman/listinfo/fusion-users
More information about the fusion-users mailing list
