[fusion-users] Re: Toolbar's Button Item disabled by default
firework alex_taillon at msn.com
Wed Mar 21 19:31:19 EDT 2012
Yes, the Fusion.Event.MAP_LOADED did the trick. thx
But the XML did work. It did actually but got enable back by some other
event... I think... maybe by some Widget_State_Changed event in the
ApplicationDefinition.js
Thank you all for your replies...
P.S. In case you need to reproduce this behavior and test, I'm working with
last week trunk version
( needed the jxLib 3...)
View this message in context: http://osgeo-org.1560.n6.nabble.com/Toolbar-s-Button-Item-disabled-by-default-tp4639181p4642756.html
Sent from the Fusion Users mailing list archive at Nabble.com.
More information about the fusion-users mailing list
