[fusion-users] Re: Unable to display map using fusion
Zac Spitzer zac.spitzer at gmail.com
Wed May 2 07:24:44 EDT 2012
looking at the code, it seems fusion uses the PHP MapScript ms_newMapObj()
to parse your map file, which I think is where it is falling over.
here is some doco
http://www.mapserver.org/mapscript/php/index.html
I'd suggest try googling 'MapScriptException' with message 'Property
'imagetype'
or checking the mapserver mailing list archives
I am part of the MapGuide Team and have zero experience with mapserver stuff
z
On Wed, May 2, 2012 at 8:43 PM, Badrul <badruls007 at yahoo.com> wrote:
> Hi zac
> As told by you on twitter to have look at source code, as you can see above
> i have included my map file source code and here i am doing it again
> MAP
>  NAME "uktest2"
>  # Map image size
>  SIZE 9900 8000
>  UNITS meters
>  SHAPEPATH "C:\UKBoundary\UKBoundary.shp"
>  EXTENT -689447.628994 -22878.477049 1344447.892830 1250227.410037
>  FONTSET 'C:\fonts.txt'
>  SYMBOLSET 'C:\symbols.txt'
>  # Background color for the map canvas -- change as desired
>  IMAGECOLOR 240 255 240
>  IMAGEQUALITY 95
>  IMAGETYPE PNG
>  OUTPUTFORMAT
>    NAME agg
>    DRIVER AGG/PNG
>    IMAGEMODE RGB
>  END
>  LAYER
>    NAME "UKBoundary"
>    DATA UKBoundary
>    STATUS DEFAULT
>    TYPE LINE
>    CLASS
>       NAME 'UKBoundary'
>       STYLE
>         WIDTH 4.36
>         COLOR 0 0 0  #255 140 0
>        OUTLINECOLOR 94 150 193
>       END
>    END
>  END
>  LAYER
>    NAME 'LiveSites'
>    TYPE POINT
>    DUMP true
>    EXTENT 492264.819731 239288.251847 568064.802479 287960.850589
>    DATA '../../Documents and
> Settings/bght1924/Desktop/LiveSites/LiveSites.shp'
>    #SHAPEPATH "C:\UKBoundary\LiveSites.shp"
>    METADATA
>      'ows_title' 'LiveSites'
>    END
>    STATUS DEFAULT
>    TRANSPARENCY 100
>    CLASS
>       NAME 'LiveSites'
>       STYLE
>         SYMBOL "circle"
>         SIZE 7.0
>         OUTLINECOLOR 0 0 0
>         COLOR 157 88 159
>       END
>    END
>  END
> END
> Since error is related to imagetype property i am not getting where problem
> lies in my map file as i have written following code
>  IMAGEQUALITY 95
>  IMAGETYPE PNG
>  OUTPUTFORMAT
>    NAME agg
>    DRIVER AGG/PNG
>    IMAGEMODE RGB
>  END
> I am not able to understand what is problem with it.
> Thanks & Regards
> Badrul
> View this message in context: http://osgeo-org.1560.n6.nabble.com/Unable-to-display-map-using-fusion-tp4715312p4945860.html
> Sent from the Fusion Users mailing list archive at Nabble.com.
> fusion-users mailing list
> fusion-users at lists.osgeo.org
> http://lists.osgeo.org/mailman/listinfo/fusion-users
Zac Spitzer
Solution Architect / Director
Ennoble Consultancy Australia
http://www.ennoble.com.au
http://zacster.blogspot.com
+61 405 847 168
More information about the fusion-users mailing list
