[fusion-users] Overview Map
elliott17 elliottd at ae.ca
Mon Sep 17 08:49:42 PDT 2012
I am having this issue with MGOS 2.2 on server 2008 IIS 7. The Overview Map
is showing the contents in LL where my main map is set to
WGS84.PseudoMercator. The OverviewMap.js is shown below. Will the following
line of code help in this issue:
this.mapObject.projection = this.getMap().oMapOL.getProjection();
this.mapObject.oLayerOL.projection = this.getMap().oMapOL.getProjection();
loadOverview: function()
        if (this.control) {
          this.control.destroy();
        var layer = this.mapObject.oLayerOL;
        if(layer != null)
            var size = $(this.domObj).getContentBoxSize();
            this.oSize = new OpenLayers.Size(size.width, size.height);
            layer.isBaseLayer = true;
            layer.ratio = 1.0;
            if (layer.singleTile) {
              this.oMapOptions.numZoomLevels = 3;  //TODO: make this
configurable?
            var options = {
              div: this.domObj,
              minRatio: this.nMinRatio,
              maxRatio: this.nMaxRatio,
              mapOptions: this.oMapOptions,
              layers: [layer]
            this.control = new OpenLayers.Control.OverviewMap(options);
            if (size.width == 0 || size.height == 0)
                return;   //don't try to load if the container is not
visible
            else
                this.getMap().oMapOL.addControl(this.control);
                this.bDisplayed = true;
            //console.log('OverviewMap mapLoaded');
View this message in context: http://osgeo-org.1560.n6.nabble.com/Overview-Map-tp3781261p5002385.html
Sent from the Fusion Users mailing list archive at Nabble.com.
More information about the fusion-users mailing list
