[fusion-users] Adding Events In Fusion
Zac Spitzer zac.spitzer at gmail.com
Tue Nov 26 22:56:43 PST 2013
that version of mapguide and fusion is ancient, can you upgrade?
the amount of bug fixes, performance improvement and improvements
since 2.2 are huge
On Wed, Nov 27, 2013 at 5:49 PM, Rodolfo Moreno <rodolfoamoreno at gmail.com>wrote:
> Hi All,
> I want to add an event to fusion, exactly in the moment when the user turns
> on or off a layer.
> I saw the code sample in the COOKBOOK:
> http://trac.osgeo.org/fusion/wiki/Cookbook/Fusion/Events
> I followed all steps of the COOKBOOK however I get an error on the
> following
> line:
> stateChanged: function(obj, event) {
>         if (obj.legend && obj.legend.treeItem.checkBox) {
>             if (obj.legend.treeItem.checkBox.checked) {
>                 *this.triggerEvent(Fusion.Event.LEGEND_LAYER_VIS_ON, obj);*
>                 obj.show();
>             } else {
>                 this.triggerEvent(Fusion.Event.LEGEND_LAYER_VIS_OFF, obj);
>                 obj.hide();
>         OpenLayers.Event.stop(event, true);
> The message that I got is: "The object does not support this property or
> method"
> In the debug mode I saw that effectively *this* object does not have the
> triggerEvent method.
> I suppose that this error is due to the code sample from the cookbook is
> related with older fusion versions.
> I am using the fusion version that come with MapGuide OS 2.2
> I would appreciate so much for any suggestions. Thanks in advance.
> Rodolfo
> http://osgeo-org.1560.x6.nabble.com/Adding-Events-In-Fusion-tp5091395.html
> Sent from the Fusion Users mailing list archive at Nabble.com.
> fusion-users mailing list
> fusion-users at lists.osgeo.org
> http://lists.osgeo.org/mailman/listinfo/fusion-users
Zac Spitzer
+61 405 847 168
URL: <http://lists.osgeo.org/pipermail/fusion-users/attachments/20131127/10b2278b/attachment.html>
More information about the fusion-users mailing list
