[gdal-dev] Re: CVS Access
Frank Warmerdam warmerda at h...
Thu Dec 3 22:07:10 EST 1998
Daniel Morissette wrote:
> It did work with the new hostname, but then I had to use 'cvs login'
> before the checkout and could not login with user 'warmerda' (of
> course!) so I used my personal account on your system and was able to
> checkout part of the source tree but not all of it. It failed to create
> a lock file at some point, probably because my personal account did not
> have permissions to write to that directory. FYI, here is what I got:
> D:\proj\gdal\src>cvs checkout gdal
> cvs server: Updating gdal
> cvs server: Updating gdal/apps
> U gdal/apps/GNUmakefile
> U gdal/apps/gdalinfo.c
> cvs server: Updating gdal/core
> U gdal/core/GNUmakefile
> U gdal/core/gdal.h
> U gdal/core/gdal_priv.h
> U gdal/core/gdaldataset.cpp
> U gdal/core/gdaldriver.cpp
> U gdal/core/gdaldrivermanager.cpp
> U gdal/core/gdalopen.cpp
> U gdal/core/gdalrasterband.cpp
> cvs server: Updating gdal/frmts
> cvs server: failed to create lock directory in repository
> `/usr/cvsroot/gdal/frmts': Permission denied
> cvs server: failed to obtain dir lock in repository
> cvs [server aborted]: read lock failed - giving up
Daniel,
I have chmod -r g+w my /usr/cvsroot tree. Could you try again, and see
if it works now?
I will eventually setup anonymous access to the CVS repository, but for
now was planning to give real accounts to those interested (still a
small group).
Later,
Who can give them back their lives | Frank Warmerdam, Software Developer
and all those wasted years? - Rush | URL http://members.home.com/warmerda
| warmerda at h...
Free Web-based e-mail groups -- http://www.eGroups.com
