[gdal-dev] Problem compiling GDAL
Aleksey Naumov naumov at a...
Wed Jun 21 13:55:40 EDT 2000
Frank,
I had -P (prune) option for cvs checkout, that's why... Thanks!
Aleksey
Frank Warmerdam wrote:
> Aleksey Naumov wrote:
> > Dear Frank and all developers,
> > I just checked out GDAL from OSRS CVS and tried to compile it. I got
> > an error in 'frmts' directory:
> > make[1]: Entering directory `/home/aleksey/Geog/GDAL/gdal/frmts'
> > c++ -c -Wall -fPIC -O2 -I.. -I../port -I../core -I../ogr -DFRMT_gxf
> > -DFRMT_gtiff -DFRMT_hfa -DFRMT_a
> > igrid -DFRMT_ceos -DFRMT_ceos2 -DFRMT_elas -DFRMT_iso8211
> > -DFRMT_sdts -DFRMT_raw -DFRMT_dted -DFRM
> > T_zlib -DFRMT_jpeg -DFRMT_png \
> > -DGDAL_FORMATS="gxf gtiff hfa aigrid ceos ceos2 elas iso8211 sdts raw
> > dted zlib jpeg png " \
> > gdalallregister.cpp -o o/gdalallregister.o
> > Assembler messages:
> > FATAL: Can't create o/gdalallregister.o: No such file or directory
> > make[1]: *** [o/gdalallregister.o] Error 1
> > make[1]: Leaving directory `/home/aleksey/Geog/GDAL/gdal/frmts'
> > make: *** [frmts-target] Error 2
> > Is "o/" in "o/gdalallregister.o" meant to be a new directory, is it a
> > typo, or something else?
> Aleksey,
> There should be a gdal/frmts/o directory created when you check out of
> CVS. The only thing it will contain initially is the CVS directory. Is
> it not there? If not, you could create it by hand, but something apparently
> went wrong in your checkout ... you might want to recreate the whole tree.
> Let me know what happens.
> Later,
> I set the clouds in motion - turn up | Frank Warmerdam, warmerda at h...
> light and sound - activate the windows | http://members.home.com/warmerda
> and watch the world go round - Rush | Geospatial Programmer for Rent
> $BCg4V$H$O$8$a$k!"Cg4V$r8+$D$1$k!!#e%0%k!<%W(B
> $B!!!!!!!V%0%k!<%W%a!<%k$7$^$;$s$+!)!W(B
> $B%5!<%/%k!&F1Ak2q!&F1N=!&%S%8%M%9!&2HB2$G$I$&$>!*(B
> $B!!(Bhttp://www.egroups.co.jp/info/features.html
> http://click.egroups.com/1/3411/3/_/23095/_/961602687/
