Stuck trying to translate ArcGrid Binary Data
rupert at i... rupert at i...
Sat Apr 28 01:38:47 EDT 2001
Hello,
I am looking to translate some binary ArcGrid data to a form such as
Ascii ArcGrid or tiff to use in a tool such as Teragen or GenesisII.
When I run gdalinfo on the data i get the following:
C:\Downloads\gdal-114-ntbin\gdal114\bin>gdalinfo gx25dem
Driver: AIG/Arc/Info Binary Grid
Size is 928, 918
Coordinate System is `'
Origin = (2722695.925926,6228446.759259)
Pixel Size = (25.000000,-25.000000)
Corner Coordinates:
Upper Left ( 2722695.926, 6228446.759)
Lower Left ( 2722695.926, 6205496.759)
Upper Right ( 2745895.926, 6228446.759)
Lower Right ( 2745895.926, 6205496.759)
Center ( 2734295.926, 6216971.759)
Band 1 Block=256x4 Type=Int32, ColorInterp=Undefined
Min=700.000/1, Max=2797.000/1
Now I want to convert this into something else like a jpeg so that I
can use this as height data image.
What exactly do I do within gdal_translate? I have tried such things
as this:
C:\Downloads\gdal-114-ntbin\gdal114\bin>gdal_translate -of AIG
gx25dem test.tif
With this response...
Size is 928, 918
0.ERROR 6: GDALDriver::Create() ... no create method implemented for
this format
What am I doing wrong?
Thanks
Rupert
