[gdal-dev] How to declare State Plane coordinates?
Ben Discoe ben at v...
Mon Aug 13 02:45:12 EDT 2001
> Ben,
> I am attaching a list of USGS state plane zone numbers
Thanks, they work great! I turned it into a C header file, so that i could
compile it into my library to reduce dependence on finding an external file
at runtime, although..
> Note that the SetStatePlane() method won't even work if the EPSG
> tables are not accessable.
Indeed. I did find that i needed to set GEOTIFF_CSV to point to my
gdal/data location. That's OK though, i can probably figure out a way to
get end-users set up appropriately.
-Ben
