small problem in OGRSpatialReference::IsSame?
Ben Discoe ben at v...
Mon Aug 13 03:00:37 EDT 2001
I found that OGRSpatialReference::IsSame seems to fail in the following
case:
OGRSpatialReference one; // "geographical"
OGRSpatialReference two; // "projected", e.g. UTM
int same = one.IsSame(&two);
This returns True when it should return False.
I suspect this could be caught with a check like
if( IsProjected() != poOtherSRS->IsProjected() )
return FALSE;
One other little nit: 'equivalent' is spelled 'equivelent' 20-or-so times in
the gdal source tree.
Thanks,
Ben
