[gdal-dev] Re: Update on ESA SAR header (GDAL)
Markus Neteler neteler at i...
Fri Aug 31 11:30:27 EDT 2001
Frank,
On Fri, Aug 31, 2001 at 11:19:01AM -0400, Frank Warmerdam wrote:
> Markus Neteler wrote:
> > On Fri, Aug 31, 2001 at 10:18:04AM -0400, Frank Warmerdam wrote:
> > Frank,
> > it seems that ESA SAR Toolbox wants:
> > slc1.img0
> > slc1.ldr0
> > slc1.nul0
> > slc1.vdf0
> Markus,
> I have added support for this SAR file naming convention, and it seems to
> work here.
Thanks a LOT! It works fine here... Maybe the way is open now
for built-in geocoding in r.in.gdal (as you mentioned recently)?
Thanks again,
Markus
