[gdal-dev] libproj.so on Linux?
Ben Discoe ben at v...
Thu Dec 27 15:10:04 EST 2001
> -----Original Message-----
> From: Daniel Morissette [mailto:danmo at v...]
> Make sure /usr/local/lib is in your runtime libpath: edit
> /etc/ld.so.conf to add /usr/local/lib, and then run "/sbin/ldconfig".
> This will permanently add /usr/local/lib to your system's runtime lib
> path.
Sure enough, i ran "/sbin/ldconfig" again as root, and it seems to have
fixed the problem! <scratches head> It's puzzling, since i had already
added /usr/local/lib long ago, and other libraries in that folder were
already working and being found... i guess "ldconfig" does more than just
check the paths in ld.so.conf.
Anyhow, it's very exciting, my apps are running on Linux! Now there's just
a matter of fixing all the bugs that are only happening on Linux..
Thanks,
Ben
