[gdal-dev] GDAL organization chart
Frank Warmerdam warmerdam at p...
Thu Mar 15 07:29:28 EST 2001
Ben Discoe wrote:
> One particular point is MITAB. I have drawn it as: The MapInfo part of OGR
> uses MITAB, MITAB in turn calls parts of OGR. Is it so? Must MITAB be
> built as a separate library? Is a version of it included with OGR, or with
> GDAL?
Ben,
All the required MITAB source can be found within the GDAL source tree
(in gdal/ogr/ogrsf_frmts/mitab), so no, MITAB need not be built separately.
The chart is nice ... what tool did you use for it? Unfortunately it doesn't
really express everything I would like. I always try to put too much into
charts.
Best regards,
I set the clouds in motion - turn up | Frank Warmerdam, warmerdam at p...
light and sound - activate the windows | http://pobox.com/~warmerda
and watch the world go round - Rush | Geospatial Programmer for Rent
