[gdal-dev] Compiling on cygwin
Frank Warmerdam warmerdam at p...
Tue Nov 6 17:30:44 EST 2001
Tyler Mitchell wrote:
> Hi guys,
> Is there anything special I need to do to get gdal compiled on cygwin?
> Here's the error I'm getting:
> ./configure --with-tiff=internal --with-geotiff=internal
> --with-jpeg=internal
> #I have also enabled ECW support
> make clean
> make
> /usr/lib/libm.a(_cygwin_crt0_common.o): In function `cygwin_crt0_common':
> /cygnus/netrel/src/cygwin-1.3.3-2/winsup/cygwin/lib/_cygwin_crt0_common.cc:90:
> u
> ndefined reference to `GetModuleHandleA at 4'
> make: *** [force-lib] Error 1
> Administrators at PCWLF20 /usr/src/gis/gdal-1.1.5
Tyler,
I have never run into this problem, and I am not sure where GetModuleHandleA
is being called from. Note that I have never tried using ECW from within
Cygwin. I didn't realize you were supposed to be able to call out to external
DLLs without doing something special. Perhaps you could try it again without
ECW and see if that is your problem?
Best regards,
I set the clouds in motion - turn up | Frank Warmerdam, warmerdam at p...
and watch the world go round - Rush | Geospatial Programmer for Rent
