[gdal-dev] GDALDefaultOverviews
Frank Warmerdam warmerdam at p...
Tue Oct 2 09:16:27 EDT 2001
Andreas Ögren wrote:
> Hi!
> I'm new to GDAL and I've just started to do a test implementation to see
> how it works. There is one problem though, after including
> "gdal_priv.h" my VC6 sp5 compiler says that "class
> 'GDALDefaultOverviews' needs to have dll-interface to be used by clients
> of class 'GDALDataset'" (line 232). Any ideas what might be the problem?
Andreas,
I am not sure why this is affecting you, and not me, but the fix should be
easy. I have commited it to CVS, but basically, you just add CPL_DLL between
"class" and "GDALDefaultOverviews" in the class declaration for this class in
gdal_priv.h.
eg.
/* GDALDefaultOverviews */
class CPL_DLL GDALDefaultOverviews
GDALDataset *poDS;
GDALDataset *poODS;
char	*pszOvrFilename;
Let me know if this doesn't solve your problem. You will likely need to
do a clean build.
Best regards,
I set the clouds in motion - turn up | Frank Warmerdam, warmerdam at p...
and watch the world go round - Rush | Geospatial Programmer for Rent
