[gdal-dev] new version
Frank Warmerdam warmerdam at p...
Tue Sep 25 12:19:15 EDT 2001
Diana,
Sorry, I forgot the attachment in my last message. It should be there now.
Best regards,
I set the clouds in motion - turn up | Frank Warmerdam, warmerdam at p...
and watch the world go round - Rush | Geospatial Programmer for Rent
name="gdalmajorobject.cpp"
Content-Transfer-Encoding: 7bit
Content-Disposition: inline;
filename="gdalmajorobject.cpp"
* $Id: gdalmajorobject.cpp,v 1.4 2001/09/25 15:56:37 warmerda Exp $
* Project: GDAL Core
* Purpose: Base class for objects with metadata, etc.
* Author: Frank Warmerdam, warmerda at h...
* Copyright (c) 2000, Frank Warmerdam
* Permission is hereby granted, free of charge, to any person obtaining a
* copy of this software and associated documentation files (the "Software"),
* to deal in the Software without restriction, including without limitation
* the rights to use, copy, modify, merge, publish, distribute, sublicense,
* and/or sell copies of the Software, and to permit persons to whom the
* Software is furnished to do so, subject to the following conditions:
* The above copyright notice and this permission notice shall be included
* in all copies or substantial portions of the Software.
* THE SOFTWARE IS PROVIDED "AS IS", WITHOUT WARRANTY OF ANY KIND, EXPRESS
* OR IMPLIED, INCLUDING BUT NOT LIMITED TO THE WARRANTIES OF MERCHANTABILITY,
* FITNESS FOR A PARTICULAR PURPOSE AND NONINFRINGEMENT. IN NO EVENT SHALL
* THE AUTHORS OR COPYRIGHT HOLDERS BE LIABLE FOR ANY CLAIM, DAMAGES OR OTHER
* LIABILITY, WHETHER IN AN ACTION OF CONTRACT, TORT OR OTHERWISE, ARISING
* FROM, OUT OF OR IN CONNECTION WITH THE SOFTWARE OR THE USE OR OTHER
* DEALINGS IN THE SOFTWARE.
* $Log: gdalmajorobject.cpp,v $
* Revision 1.4 2001/09/25 15:56:37 warmerda
* implemented rest of C entry points for metadata, document C++ methods
* Revision 1.3 2001/07/18 04:04:30 warmerda
* added CPL_CVSID
* Revision 1.2 2000/06/26 15:26:21 warmerda
* added GDALGetDescription
* Revision 1.1 2000/04/20 20:52:03 warmerda
* New
#include "gdal_priv.h"
#include "cpl_string.h"
CPL_CVSID("$Id: gdalmajorobject.cpp,v 1.4 2001/09/25 15:56:37 warmerda Exp $");
/* GDALMajorObject() */
GDALMajorObject::GDALMajorObject()
pszDescription = NULL;
papszMetadata = NULL;
/* ~GDALMajorObject() */
GDALMajorObject::~GDALMajorObject()
CPLFree( pszDescription );
CSLDestroy( papszMetadata );
/* GetDescription() */
* Fetch object description.
* The semantics of the returned description are specific to the derived
* type. For GDALDatasets it is the dataset name, as could be (or perhaps
* was) used with GDALOpen().
* @return pointer to internal description string.
const char *GDALMajorObject::GetDescription() const
if( pszDescription == NULL )
return "";
else
return pszDescription;
/* GDALGetDescription() */
const char *GDALGetDescription( GDALMajorObjectH hObject )
return ((GDALMajorObject *) hObject)->GetDescription();
/* SetDescription() */
void GDALMajorObject::SetDescription( const char * pszNewDesc )
pszDescription = CPLStrdup( pszNewDesc );
/* GetMetadata() */
* Fetch metadata.
* The returned string list is owned by the object, and may change at
* any time. It is formated as a "Name=value" list with the last pointer
* value being NULL. Use the the CPL StringList functions such as
* CSLFetchNameValue() to manipulate it.
* Note that relatively few formats return any metadata at this time.
* This method does the same thing as the C function GDALGetMetadata().
* @param pszDomain the domain of interest. Use "" or NULL for the default
* domain.
* @return NULL or a string list.
char **GDALMajorObject::GetMetadata( const char * pszDomain )
if( pszDomain == NULL || EQUAL(pszDomain,"") )
return papszMetadata;
else
return NULL;
/* GDALGetMetadata() */
char **GDALGetMetadata( GDALMajorObjectH hObject, const char * pszDomain )
return ((GDALMajorObject *) hObject)->GetMetadata(pszDomain);
/* SetMetadata() */
* Set metadata.
* The C function GDALSetMetadata() does the same thing as this method.
* @param papszMetadata the metadata in name=value string list format to
* apply.
* domain.
* @return CE_None on success, CE_Failure on failure and CE_Warning if the
* metadata has been accepted, but is likely not maintained persistently
* by the underlying object between sessions.
CPLErr GDALMajorObject::SetMetadata( char ** papszMetadataIn,
if( pszDomain != NULL && !EQUAL(pszDomain,"") )
CPLError( CE_Failure, CPLE_NotSupported,
"Non-default domain not supported for this object." );
return CE_Failure;
papszMetadata = CSLDuplicate( papszMetadataIn );
return CE_None;
/* GDALSetMetadata() */
CPLErr GDALSetMetadata( GDALMajorObjectH hObject, char **papszMD,
const char *pszDomain )
return ((GDALMajorObject *) hObject)->SetMetadata( papszMD, pszDomain );
/* GetMetadataItem() */
* Fetch single metadata item.
* The C function GDALGetMetadataItem() does the same thing as this method.
* @param pszName the key for the metadata item to fetch.
* @param pszDomain the domain to fetch for, use NULL for the default domain.
* @return NULL on failure to find the key, or a pointer to an internal
* copy of the value string on success.
const char *GDALMajorObject::GetMetadataItem( const char * pszName,
char **papszMD = GetMetadata( pszDomain );
return CSLFetchNameValue( papszMD, pszName );
/* GDALGetMetadataItem() */
const char *GDALGetMetadataItem( GDALMajorObjectH hObject,
const char *pszName,
return ((GDALMajorObject *) hObject)->GetMetadataItem( pszName, pszDomain);
/* SetMetadataItem() */
* Set single metadata item.
* The C function GDALSetMetadataItem() does the same thing as this method.
* @param pszValue the value to assign to the key.
* @param pszDomain the domain to set within, use NULL for the default domain.
* @return CE_None on success, or an error code on failure.
CPLErr GDALMajorObject::SetMetadataItem( const char * pszName,
const char * pszValue,
return CE_Failure;
papszMetadata = CSLSetNameValue( papszMetadata, pszName, pszValue );
return CE_None;
/* GDALSetMetadataItem() */
CPLErr GDALSetMetadataItem( GDALMajorObjectH hObject,
const char *pszName, const char *pszValue,
return ((GDALMajorObject *) hObject)->SetMetadataItem( pszName, pszValue,
pszDomain );
