[gdal-dev] using GIO driver to create grids
Frank Warmerdam warmerdam at p...
Thu Apr 4 15:12:53 EST 2002
Andrew.Loughhead at c... wrote:
> Just wondering if anyone has a working example of using the
> GIO driver to create new ESRI grids, that they could share
> with me, either using the C++ or C interface. Along the lines
> of Franks tutorial is what I'm hoping for. I have code that
> creates a grid and apparently writes to it, but when looked
> at in Arc/Info, the results are entirely nodata.
Andrew,
Any possibility you aren't closing the destination dataset properly?
Does gdal_translate to GIO format work?
Best regards,
I set the clouds in motion - turn up | Frank Warmerdam, warmerdam at p...
and watch the world go round - Rush | Geospatial Programmer for Rent
