any reason for a linked statically gdalinfo?
gdal_dev_reader alessandro_amici at t...
Mon Aug 19 13:02:55 EDT 2002
Frank,
in the apps/GNUmakefile i find:
gdalinfo$(EXE): gdalinfo.o $(DEP_LIBS)
$(CXX) $(LNK_FLAGS) gdalinfo.o $(XTRAOBJ) $(GDAL_LIBS) $(LIBS) \
-o gdalinfo$(EXE)
gdal_translate$(EXE): gdal_translate.o $(DEP_LIBS)
$(CXX) $(LNK_FLAGS) gdal_translate.o $(XTRAOBJ) \
$(CONFIG_LIBS) -o gdal_translate$(EXE)
is there any special reason for gdalinfo to be always linked
statically? all other apps seem to be linked dinamically when
possible.
i build libgdal.1.1.so as a shared library and dinamic link saves
some disk space with no apparent (to me:)) loss:
gdalinfo.static is 1139844 bytes
gdalinfo.dinamic is 15896 bytes
cheers,
alessandro
