[gdal-dev] Re: any reason for a linked statically gdalinfo?
Buchan Milne bgmilne at c...
Tue Aug 20 13:27:55 EDT 2002
gdal_dev_reader wrote:
>>I have put a gdal package into Mandrake, using the default make rule,
>>halving it's size is appealing ...
> here are the sizes i have :) (with hand-make dynamic link on debian):
> -rw-r--r-- 1 amici amici 1308560 Aug 20 15:39 gdal-bin_1.1.7-1.1_i386.deb
> -rw-r--r-- 1 amici amici 1605506 Aug 20 15:39 libgdal0-dev_1.1.7-1.1_i386.deb
> -rw-r--r-- 1 amici amici 1077956 Aug 20 15:39 libgdal0_1.1.7-1.1_i386.deb
> -rw-r--r-- 1 amici amici 47504 Aug 20 15:39 python-gdal_1.1.7-1.1_i386.deb
> the four packages contain anything produced by make install plus
> some redundancy in administrative files.
OK, I have this in cooker contrib at the moment:
[bgmilne at printserver RPMS]$ ls *gdal* -l
-rw-r--r-- 1 bgmilne adm 1775889 Aug 16 18:45
gdal-1.1.7-2mdk.i586.rpm
-rw-r--r-- 1 bgmilne adm 41789 Aug 16 18:45
gdal-python-1.1.7-2mdk.i586.rpm
-rw-r--r-- 1 bgmilne adm 817070 Aug 16 18:45
libgdal0-1.1.7-2mdk.i586.rpm
-rw-r--r-- 1 bgmilne adm 1501677 Aug 16 18:45
libgdal0-devel-1.1.7-2mdk.i586.rpm
At least we settled on the same major number, what do you propose about
gdal-python? (In terms of keeping package names consistent?) Do you want
to change or should I?
> the ogr library is staic only.
>>Btw, any time frame for SONAME support?
> Frank,
> you allowed people to ping you on that starting on mid july... :)
> if you agree i can submit a patch for GNUmakefile and
> GDALmake.opts.in that enable SONAME support for GNU binutils.
> what i'm not able to do is to twist the configure script to
> identify a GNU target, final touch needs to be yours ;)
Could you mail the patch to me or the list?
But that's going to mean I have to rebuild grass .... :-( Maybe I should
leave it till after 9.0 is out, or maybe I shouldn't let un-SONAMED libs
into a stable distro - sounds like I'll be rebuilding grass.
Buchan
|----------------Registered Linux User #182071-----------------|
Buchan Milne Mechanical Engineer, Network Manager
Cellphone * Work +27 82 472 2231 * +27 21 8828820x121
Stellenbosch Automotive Engineering http://www.cae.co.za
GPG Key http://ranger.dnsalias.com/bgmilne.asc
1024D/60D204A7 2919 E232 5610 A038 87B1 72D6 AC92 BA50 60D2 04A7
