[gdal-dev] Use of the virtual dataset/rasterband
Frank Warmerdam warmerdam at p...
Wed Aug 28 08:34:39 EDT 2002
Paul Selormey wrote:
> Hello,
> Anybody at home?
Paul,
Yes, somebody somewhere is at home. In fact, even I am.
> What is the use of the dataset/rasterband objects?
> Sorry, I mean the virtual dataset object (it contains some stuff
> relating to XML), but I could not get the purpose of the dataset.
The virtual dataset "format" is a way of writing an XML description of a
dataset where the image data is derived from other GDAL supported datasets.
It has a number of potential uses including:
o A way of creating a dataset with different, or complete metadata without
copying image data.
o A mechanism to merge bands from many files into one.
o A way to create a subsetted dataset (without copying image).
o A way to build a virtual mosaic from a set of data files.
Best regards,
I set the clouds in motion - turn up | Frank Warmerdam, warmerdam at p...
and watch the world go round - Rush | Geospatial Programmer for Rent
