[Gdal-dev] gt_wkt_srs.cpp broken?
Sun Dec 1 16:13:03 EST 2002
Vladimir Slepnev wrote:
> Hello again.
> For some reason, the current version of GDAL taken from CVS doesn't build on
> my system.
> Here is the error:
> gt_wkt_srs.cpp(256) : error C2660: 'GTIFGetPCSInfo' : function does not take
> 6 parameters
> Is it just me?
Vladimir,
Have you done a CVS update of the whole GDAL tree?  The change in the
argument list of GTIFGetPCSInfo() is part of the EPSG 6.2.2 change.  Note
that you will also want to install the new EPSG support files via a
make install of GDAL if you want GeoTIFF PCS lookup support to work.
Best regards,
