[Gdal-dev] Landsat 7 TM
javier garcia andresjavier.garcia at wanadoo.es
Tue Dec 10 13:20:58 EST 2002
Hi, Andrey.
gdalinfo --formats doesn't work for me. What I can do is:
>gdalinfo --version
GDAL 1.1.7, released 2002/04/16
Do you think is it too old to support FAST: EOSAT FAST Format?
Could you tell me if the output of your "gdalinfo --version" is different
than mine?
Thanks,
Javier
El Mar 10 Dic 2002 18:09, escribió:
> Hi, Javier,
> > I've compiled GRAS5.0 against gdal-1.1.7.1 (downloaded from binaries for
> > Linux); but I can't import FAST-L7A format (Landsat TM data). I obtain a
> > message that says that the format is not supported.
> > It seems to be a problem of gdal. Isn't it?
> > If so. Can we expect to import this shortly?
> What do you get with the
> gdalinfo --formats
> command? If output of this command do not contain string
> ``FAST: EOSAT FAST Format'' then you need more up to date GDAL library.
> You should compile it from sources in this case. Latest source snapshot
> may be downloaded from
> ftp://ftp.remotesensing.org/gdal/daily
> 				Regards,
> 				Andrey
