[Gdal-dev] boolean data type?
Wed Dec 11 09:52:43 EST 2002
Vincent Schut wrote:
> Does anybody know of a boolean data type supported by GDAL? I am making
> masks for several gigabytes of data (timeseries) and it would save me
> quite some diskspace if I could save them as bits instead of bytes...
> I think tiff theoretically could be b/w instead of grayscale, but I
> can't find a GDT_bool like datatype...
> I could of course just write the raw boolean data to disk as it will
> always be coupled with some georeferenced other data file, but it would
> be nicer to have it in some GDAL supported format.
Vincent,
There is no 1bit data type even though there is a decent case to be made for
it's support.   Partly I avoid it because having a less-than-a-byte data
type will complicate alot of code.
I would suggest you save treat your masks as 8bit data, and save in a
compressed format, such as COMPRESS=DEFLATE with GeoTIFF.  This should
pack the data down to the minimum required, hopefully less than uncompressed
1bit data.
Best regards,
