[Gdal-dev] Re: GDAL
Thu Dec 12 09:58:15 EST 2002
Hubert Fröhlich wrote:
> Hello Frank,
> I got an error like
> ERROR 4: `out.tif' does not exist in the file system,
> and is not recognised as a supported dataset name.
Hubert,
Note that the error above about out.tif is not significant.  Before
creating the output file the script checks to see if it already exists
by trying to open it.  This message is the report that it failed.
Ideally I would install an error handler to supress reporting this
message, but this is not yet convenient to do from Python with the
GDAL bindings I have implemented so far.
> Traceback (most recent call last):
>  File "/usr/lib/python2.1/site-packages/gdal_merge.py", line 293, in ?
>    file_infos[0].band_type, '' )
>  File "/usr/lib/python2.1/site-packages/gdal.py", line 305, in Create
>    bands, datatype, options )
> TypeError: GDALCreate() argument 7 must be list, not string
This is due to a small bug in gdal_merge.py.  You can just remove
the last argument in the gdal.Create() call.  I have committed this
fix to CVS.
However, once that is fixed, you will still have the problem that the pseudo
color table is not copied to the newly created file.  You are working with
a pseudocolored input, right?
I have added the -pct flag to gdal_merge.py.  The interpretation of this
is to copy the pseudocolor table from the first input file to the newly
created output file.  Note that no checking is done to ensure that the
pseudocolor tables of all input files are compatible.  If they are not,
the merged results will not be meaningful.
I have attached this improved gdal_merge.py to this email.  Let me know
how it goes.
Best regards,
#!/usr/bin/env python
# $Id: gdal_merge.py,v 1.5 2002/12/12 14:54:42 warmerda Exp $
# Project:  InSAR Peppers
# Purpose:  Module to extract data from many rasters into one output.
# Author:   Frank Warmerdam, warmerdam at pobox.com
# Copyright (c) 2000, Atlantis Scientific Inc. (www.atlsci.com)
# This library is free software; you can redistribute it and/or
# modify it under the terms of the GNU Library General Public
# License as published by the Free Software Foundation; either
# version 2 of the License, or (at your option) any later version.
# This library is distributed in the hope that it will be useful,
# but WITHOUT ANY WARRANTY; without even the implied warranty of
# MERCHANTABILITY or FITNESS FOR A PARTICULAR PURPOSE.  See the GNU
# Library General Public License for more details.
# You should have received a copy of the GNU Library General Public
# License along with this library; if not, write to the
# Free Software Foundation, Inc., 59 Temple Place - Suite 330,
# Boston, MA 02111-1307, USA.
#  $Log: gdal_merge.py,v $
#  Revision 1.5  2002/12/12 14:54:42  warmerda
#  added the -pct flag to copy over a pct
#  Revision 1.4  2002/12/12 14:48:12  warmerda
#  removed broken options arg to gdal.Create()
#  Revision 1.3  2002/04/03 21:12:05  warmerda
#  added -separate flag for Gerald Buckmaster
#  Revision 1.2  2000/11/29 20:36:18  warmerda
#  allow output file to be preexisting
#  Revision 1.1  2000/11/29 20:23:13  warmerda
#  New
import gdal
import sys
verbose = 0
def raster_copy( s_fh, s_xoff, s_yoff, s_xsize, s_ysize, s_band_n,
                 t_fh, t_xoff, t_yoff, t_xsize, t_ysize, t_band_n ):
    if verbose != 0:
        print 'Copy %d,%d,%d,%d to %d,%d,%d,%d.' \
              % (s_xoff, s_yoff, s_xsize, s_ysize,
             t_xoff, t_yoff, t_xsize, t_ysize )
    s_band = s_fh.GetRasterBand( s_band_n )
    t_band = t_fh.GetRasterBand( t_band_n )
    data = s_band.ReadRaster( s_xoff, s_yoff, s_xsize, s_ysize,
                              t_xsize, t_ysize, t_band.DataType )
    t_band.WriteRaster( t_xoff, t_yoff, t_xsize, t_ysize,
                        data, t_xsize, t_ysize, t_band.DataType )
    return 0
def names_to_fileinfos( names ):
    Translate a list of GDAL filenames, into file_info objects.
    names -- list of valid GDAL dataset names.
    Returns a list of file_info objects.  There may be less file_info objects
    than names if some of the names could not be opened as GDAL files.
    file_infos = []
    for name in names:
        fi = file_info()
        if fi.init_from_name( name ) == 1:
            file_infos.append( fi )
    return file_infos
class file_info:
    """A class holding information about a GDAL file."""
    def init_from_name(self, filename):
        Initialize file_info from filename
        filename -- Name of file to read.
        Returns 1 on success or 0 if the file can't be opened.
        fh = gdal.Open( filename )
        if fh is None:
            return 0
        self.filename = filename
        self.bands = fh.RasterCount
        self.xsize = fh.RasterXSize
        self.ysize = fh.RasterYSize
        self.band_type = fh.GetRasterBand(1).DataType
        self.projection = fh.GetProjection()
        self.geotransform = fh.GetGeoTransform()
        self.ulx = self.geotransform[0]
        self.uly = self.geotransform[3]
        self.lrx = self.ulx + self.geotransform[1] * self.xsize
        self.lry = self.uly + self.geotransform[5] * self.ysize
        ct = fh.GetRasterBand(1).GetRasterColorTable()
        if ct is not None:
            self.ct = ct.Clone()
        else:
            self.ct = None
        return 1
    def report( self ):
        print 'Filename: '+ self.filename
        print 'File Size: %dx%dx%d' \
              % (self.xsize, self.ysize, self.bands)
        print 'Pixel Size: %f x %f' \
              % (self.geotransform[1],self.geotransform[5])
        print 'UL:(%f,%f)   LR:(%f,%f)' \
              % (self.ulx,self.uly,self.lrx,self.lry)
    def copy_into( self, t_fh, s_band = 1, t_band = 1 ):
        Copy this files image into target file.
        This method will compute the overlap area of the file_info objects
        file, and the target gdal.Dataset object, and copy the image data
        for the common window area.  It is assumed that the files are in
        a compatible projection ... no checking or warping is done.  However,
        if the destination file is a different resolution, or different
        image pixel type, the appropriate resampling and conversions will
        be done (using normal GDAL promotion/demotion rules).
        t_fh -- gdal.Dataset object for the file into which some or all
        of this file may be copied.
        Returns 1 on success (or if nothing needs to be copied), and zero one
        failure.
        t_geotransform = t_fh.GetGeoTransform()
        t_ulx = t_geotransform[0]
        t_uly = t_geotransform[3]
        t_lrx = t_geotransform[0] + t_fh.RasterXSize * t_geotransform[1]
        t_lry = t_geotransform[3] + t_fh.RasterYSize * t_geotransform[5]
        # figure out intersection region
        tgw_ulx = max(t_ulx,self.ulx)
        tgw_uly = min(t_uly,self.uly)
        tgw_lrx = min(t_lrx,self.lrx)
        tgw_lry = max(t_lry,self.lry)
        # do they even intersect?
        if tgw_ulx >= tgw_lrx or tgw_uly <= tgw_lry:
            return 1
        # compute target window in pixel coordinates.
        tw_xoff = int((tgw_ulx - t_geotransform[0]) / t_geotransform[1] + 0.1)
        tw_yoff = int((tgw_uly - t_geotransform[3]) / t_geotransform[5] + 0.1)
        tw_xsize = int((tgw_lrx - t_geotransform[0])/t_geotransform[1] + 0.5) \
                   - tw_xoff
        tw_ysize = int((tgw_lry - t_geotransform[3])/t_geotransform[5] + 0.5) \
                   - tw_yoff
        if tw_xsize < 1 or tw_ysize < 1:
            return 1
        # Compute source window in pixel coordinates.
        sw_xoff = int((tgw_ulx - self.geotransform[0]) / self.geotransform[1])
        sw_yoff = int((tgw_uly - self.geotransform[3]) / self.geotransform[5])
        sw_xsize = int((tgw_lrx - self.geotransform[0]) \
                       / self.geotransform[1] + 0.5) - sw_xoff
        sw_ysize = int((tgw_lry - self.geotransform[3]) \
                       / self.geotransform[5] + 0.5) - sw_yoff
        if sw_xsize < 1 or sw_ysize < 1:
            return 1
        # Open the source file, and copy the selected region.
        s_fh = gdal.Open( self.filename )
        return \
            raster_copy( s_fh, sw_xoff, sw_yoff, sw_xsize, sw_ysize, s_band,
                         t_fh, tw_xoff, tw_yoff, tw_xsize, tw_ysize, t_band )
def Usage():
    print 'Usage: gdal_merge.py [-o out_filename] [-f out_format] [-v] [-pct]'
    print '                     [-ps pixelsize_x pixelsize_y] [-separate]'
    print '                     [-ul_lr ulx uly lrx lry] input_files'
    print
# Program mainline.
if __name__ == '__main__':
    names = []
    format = 'GTiff'
    out_file = 'out.tif'
    ulx = None
    psize_x = None
    separate = 0
    copy_pct = 0
    # Parse command line arguments.
    i = 1
    while i < len(sys.argv):
        arg = sys.argv[i]
        if arg == '-o':
            i = i + 1
            out_file = sys.argv[i]
        elif arg == '-v':
            verbose = 1
        elif arg == '-separate':
            separate = 1
        elif arg == '-pct':
            copy_pct = 1
        elif arg == '-f':
            i = i + 1
            format = sys.argv[i]
        elif arg == '-ps':
            psize_x = float(sys.argv[i+1])
            psize_y = -1 * abs(float(sys.argv[i+1]))
            i = i + 2
        elif arg == '-ul_lr':
            ulx = float(sys.argv[i+1])
            uly = float(sys.argv[i+2])
            lrx = float(sys.argv[i+3])
            lry = float(sys.argv[i+4])
            i = i + 4
        elif arg[:1] == '-':
            Usage()
            sys.exit( 1 )
        else:
            names.append( arg )
        i = i + 1
    if len(names) == 0:
        Usage()
        sys.exit( 1 )
    Driver = gdal.GetDriverByName(format)
    if Driver is None:
        print 'Format driver %s not found, pick a supported driver.' % format
        sys.exit( 1 )
    # Collect information on all the source files.
    file_infos = names_to_fileinfos( names )
    if ulx is None:
        ulx = file_infos[0].ulx
        uly = file_infos[0].uly
        lrx = file_infos[0].lrx
        lry = file_infos[0].lry
        for fi in file_infos:
            ulx = min(ulx, fi.ulx)
            uly = max(uly, fi.uly)
            lrx = max(lrx, fi.lrx)
            lry = min(lry, fi.lry)
    if psize_x is None:
        psize_x = file_infos[0].geotransform[1]
        psize_y = file_infos[0].geotransform[5]
    # Try opening as an existing file.
    t_fh = gdal.Open( out_file, gdal.GA_ReadOnly )
    # Create output file if it does not already exist.
    if t_fh is None:
        geotransform = [ulx, psize_x, 0, uly, 0, psize_y]
        xsize = int((lrx - ulx) / geotransform[1])
        ysize = int((lry - uly) / geotransform[5])
        if separate != 0:
            bands = len(file_infos)
        else:
            bands = 1
        t_fh = Driver.Create( out_file, xsize, ysize, bands,
                              file_infos[0].band_type )
        t_fh.SetGeoTransform( geotransform )
        if copy_pct:
            t_fh.GetRasterBand(1).SetRasterColorTable(file_infos[0].ct)
    # Copy data from source files into output file.
    t_band = 1
        if verbose != 0:
            print
            fi.report()
        if separate == 0 :
            fi.copy_into( t_fh )
        else:
            fi.copy_into( t_fh, 1, t_band )
            t_band = t_band+1
    # Force file to be closed.
    t_fh = None
