[gdal-dev] gdal_translate crash
Norman Vine nhv at y...
Thu Feb 7 15:56:26 EST 2002
Frank Warmerdam
>I have checked in an update gdal_translate.c with the -scale
>option. If the
>destination min/max values are omitted 0 and 256 are assumed. If the
>src min/max are omitted they will be computed from the source data (the
>same as gdalinfo -mm would report as min/max).
You meant to say 0 -> 255 right :-)
Cheers
Norman
