problem with make
pushkar_s_pradhan pushkar_s_pradhan at y...
Thu Feb 7 17:43:20 EST 2002
Thanks Frank,
I didn't know about make, moreover online docu. command was make and
not gmake and so the mistake.
--- In gdal-dev at y..., Frank Warmerdam <warmerdam at p...> wrote:
> pushkar_s_pradhan wrote:
> > Hi,
> > I have just downl. gdal 1.1.5, I run configure and then do a make
but
> > make
> > gives me this mesg.:
> > make: Fatal error: No arguments to build
> > I am using solaris 5.8 (sparc).
> > Can someone point out the problem? Thanks,
> Hi,
> The problem is likely that you are not using GNUmake. GDAL requires
GNUmake
> and the makefiles are called GNUmakefile, which isn't recognised by
the
> regular Solaris make. You might already have GNUmake as "gmake" or
"gnumake".
> If not, you will need to download it.
> Best regards,
> I set the clouds in motion - turn up | Frank Warmerdam,
warmerdam at p...
> light and sound - activate the windows | http://pobox.com/~warmerdam
> and watch the world go round - Rush | Geospatial Programmer for
Rent
