[gdal-dev] Using GRASSDataset
Frank Warmerdam warmerdam at p...
Wed Jan 23 23:11:26 EST 2002
Aleksey,
The problems are that the GDAL GRASS support doesn't recognise null values
represented as nan's for floating point values. I will try to fix this
tomorrow. Tonight I have committed changes to the grass support so that
the min/max value from the range file are read and this much is working well.
Part of the problem with the null support is that GDAL only supports null
pixels via a special "nodata" value, not via a flag separate from the
pixel data values themselves. This is OK for floating point where it is
easy to segregate a nodata value, but for byte or uint16 values there may
be no "spare" values to use.
Best regards,
I set the clouds in motion - turn up | Frank Warmerdam, warmerdam at p...
and watch the world go round - Rush | Geospatial Programmer for Rent
