[gdal-dev] Linux Binary Release
s duclos sylvain_duclos at y...
Mon May 13 15:02:13 EDT 2002
Hello Frank,
--- Frank Warmerdam <warmerdam at p...> wrote:
> I would appreciate folks trying it out, and
> reporting back on whether the
> installation mechanism works.
It work
( maybe I should have read
".. report if it doesn't work .." :)
While I'm here Frank there is 2 things in OGR/S57
ogrs57datasource.cpp:220
... LNAME_REFS ...
should read LNAM_REFS (ie the 'E')
also at s57dump.cpp:112 I replace
bRegistrarLoaded = oRegistrar.LoadInfo(
"/home/warmerda/data/s57", TRUE );
for this
bRegistrarLoaded = oRegistrar.LoadInfo( NULL, TRUE );
so that the path is found correctly.
Thanks,
Sylvain.
__________________________________________________
Do You Yahoo!?
LAUNCH - Your Yahoo! Music Experience
http://launch.yahoo.com
