[postgis-users] General Question on Raster within PostGIS
Frank Warmerdam warmerdam at p...
Tue May 14 11:45:29 EDT 2002
> While I'm here Frank there is 2 things in OGR/S57
> ogrs57datasource.cpp:220
> ... LNAME_REFS ...
> should read LNAM_REFS (ie the 'E')
Sylvain,
I have modified the code to use #define'd constants to
help avoid mistaken spelling like this. I should have done
that to start with!
> also at s57dump.cpp:112 I replace
> bRegistrarLoaded = oRegistrar.LoadInfo(
> "/home/warmerda/data/s57", TRUE );
> for this
> bRegistrarLoaded = oRegistrar.LoadInfo( NULL, TRUE );
> so that the path is found correctly.
I find it hard to believe that everyone doesn't keep the files under
"/home/warmerda/data/s57"! OK, I have changed this as suggested.
All changes are in CVS and will appear in GDAL/OGR 1.1.8 release eventually.
Best regards,
I set the clouds in motion - turn up | Frank Warmerdam, warmerdam at p...
and watch the world go round - Rush | Geospatial Programmer for Rent
