[gdal-dev] Re: OpenEV_FW_1.4.2
Tyler Mitchell tmitchell at l...
Thu May 16 11:37:45 EDT 2002
Isn't that the reference the ECW libraries?
"jlawheadus"
<jlawhead at pixsell To: gdal-dev at yahoogroups.com
.com> cc:
Fax to:
05/16/2002 07:42 Subject: [gdal-dev] Re: OpenEV_FW_1.4.2
AM
Please respond to
gdal-dev
Frank,
I downloaded OpenEV 1.4.2 on Windows 2000. I put the correct path to
the OpenEV directory tree in "setfw.bat" but when I run "openev.bat" I
get a dialog box from Python with the following error:
"The procedure entry point NCSFileTellStdIO could not be located in
the dynamic link library NCSUtil.dll"
I also have ActiveState's Python version 2.2 installed so I added the
full path to the Python executable in OpenEV to "openev.bat" just
to make sure the correct version was used. I still received the same
error.
Any ideas?
Thanks,
Joel
--- In gdal-dev at y..., Frank Warmerdam <warmerdam at p...> wrote:
> Folks,
> I have prepared a new incremental release of OpenEV_FW. This
includes
> current cuts of OpenEV and GDAL from CVS and upgrades to PROJ 4.4.5
(really
> the current CVS version).
> This cut also includes the gcps2wld.py script, and a gcps2wld.bat
file for
> generating world files from datasets with GCPs ... my real reason
for preparing
> this release.
> Best regards,
> I set the clouds in motion - turn up | Frank Warmerdam,
warmerdam at p...
> light and sound - activate the windows | http://pobox.com/~warmerdam
> and watch the world go round - Rush | Geospatial Programmer for
Rent
Your use of Yahoo! Groups is subject to the Yahoo! Terms of Service.
