[Gdal-dev] MapInfo mixing geometry types in a layer
    Ben Discoe
    ben at vterrain.org
    Thu Nov 28 15:57:58 EST 2002
Happy Thanksgiving, Frank.  Since we're both working on a holiday, i figure
i'll bug you with more questions :-)
I'm using OGR to read some MapInfo .MAP/.TAB files.  Most are working fine,
but for some of them i am encountering a strange behavior.
When i ask the type of the layer:
	OGRFeatureDefn *defn = pLayer->GetLayerDefn();
	OGRwkbGeometryType geom_type = defn->GetGeomType();
it says "OGRLineString."  However, when i am reading each geometry, some of
them are OGRLineString, and some of them are OGRMultiLineString!
Is this an expected behavior, correct OGR functioning?  Does MapInfo really
mix geometry types within a single layer, ESRI Shapefiles sure don't.
Thanks,
Ben
