[Gdal-dev] Cygwin CVS errors
Andrey Kiselev dron at ak4719.spb.edu
Tue Apr 1 11:07:30 EST 2003
On Tue, Apr 01, 2003 at 09:42:52AM -0500, Frank Warmerdam wrote:
> My gdal/ogr/ograssemblepolygon.cpp (CVS Rev 1.5) has
> OGRBuildPolygonFromEdges()
> defined as expected already:
> /*                      OGRBuildPolygonFromEdges()                      */
> OGRGeometryH OGRBuildPolygonFromEdges( OGRGeometryH hLines,
>                                        int bBestEffort,
>                                        int bAutoClose,
>                                        double dfTolerance,
>                                        OGRErr * peErr )
> Could you check that you have ograssemblepolygon.cpp 1.5?  I don't
> understand
> why you are seeing something so different.   This was apparently all
> resolved
> at the beginning of January.
Frank,
ograssemblepolygon.cpp was updated yesterday with the following log
entry:
 * Revision 1.6  2003/03/31 15:55:42  danmo
 * Added C API function docs
 * Revision 1.4  2002/03/05 15:15:07  warmerda
 * fixed zero tolerance problems
1.5 version was gone somewhere... I have the same problem as Norman.
Andrey V. Kiselev
Home phone:  +7 812 5274898  ICQ# 26871517
