[Gdal-dev] Image Reprojection
Thu Apr 3 09:55:48 EST 2003
Matt Lynch wrote:
> Hi,
> I am interested in writing or using a windows command line utility which
> will reproject GeoTiffs for me.  It seems that the gdalwarp utility is
> what I want.
> So I have a couple of questions ...
> 1.  Am I correct that gdalwarp will reproject GeoTiffs for me?  (e.g.
> UTM to Decimal Degrees)
> 2.  Are there some usage examples that I can refer to?
Matt,
I trust you have read the modest docs at:
   http://www.remotesensing.org/gdal/gdal_utilities.html#gdalwarp
Yes, it can reproject GeoTIFF files from UTM to decimal degrees.   The only
example is the one in the documentation.  To do what you want you might use:
  gdalwarp -t_srs '+proj=latlong +datum=WGS84' in.tif out.tif
Note, there is also a "gdalwarptest" in the CVS version of GDAL with similar
commandline options as gdalwarp, but using a much more sophisticated approach
internally.  In particular, it:
  o Supports a all pixel types, not just 8bit like gdalwarp.
  o Will work on images that cannot be held completely in memory.
  o Supports a variety of resamplig kernels.
  o Has "NODATA" support.
Gdalwarptest is the "test harnass" for this next generation warper.  Depending
on your needs I would appreciate help in testing this new implementation.
Best regards,
