[Gdal-dev] Image Reprojection
Thu Apr 3 13:12:33 EST 2003
Matt Lynch wrote:
> Hi Frank,
> The gdalwarptest sounds interesting.  To get an orientation I have built
> GDAL (the cleanest open source build on a windows box in a long time, by
> the way!).
> When I try to run gdalwarp I just get a usage blurb.
> C:\gdal>gdalwarp -t_srs '+proj=latlong +datum=WGS84' jeffpan2000_10m.tif
> out.tif
> Usage: gdalwarp [--version] [--formats]
>     [-s_srs srs_def] [-t_srs srs_def] [-order n] [-et err_threshold]
>     [-te xmin ymin xmax ymax] [-tr xres yres] [-ts width height]
>     [-of format] [-co "NAME=VALUE"]* srcfile dstfile
> jeffpan2000_10m.tif is in the current directory
> out.tif does not exist yet.
Matt,
I believe this is a commandline parsing issue.  The '+proj=latlong +datum=WGS84'
would be parsed as a single argument by a Unix shell, but the DOS shell doesn't
work the same.  I can think of three likely solutions:
  o Relink stuff with the SETARGV.OBJ file (see nmake.opt file for some
    discussion of this) to get more unix like argument parsing.  But this might
    only do wildcarding and not quoting.  I am unsure.
  o Use the Cygwin (http://www.cygwin.com) shell as your shell.  It provides
    Unix style commandline parsing as well as lots of other stuff.
  o Put the coordinate system definition into a file, and refer to that.
    Put "+proj=latlong +datum=WGS84" in a file called wgs84.proj4 (without any
    quotes) and then use the command:
     gdalwarp -t_srs .\wgs84.proj4 jeffpan2000_10m.tif out.tif
Best regards,
