[Gdal-dev] CFITS support
Simon Perkins s.perkins at lanl.gov
Mon Apr 7 10:42:00 EDT 2003
I was about to reply but Frank has beaten me to it. If the format you
want to use is FITS (a standard format used by astronomers) as opposed
to FIT (an obscure SGI developed format), then use '-of fits'. If that
still doesn't work, tell me where I can get an example file from and
I'll see what I can do.
Cheers,
Sy
Jim Julian wrote:
> Hi,
>    Recently I attempted to convert an Arcinfo/Arcview binary grid file
> (GIO) to FITS
> using GDAL_TRANSLATE. The first time, the program crashed. I read the
> online
> documentation and downloaded the most recent version of the CFITS
> library and DLL.
> After having placed both in the same directory, I re-tried and the
> program crashed again.
> The GIO works well as I converted the same grid to PNG, PNM, and
> GTIFF(using Uint16).
> The command-line I used is:
> C:\temp\> gdal_translate -ot float32 -of fit carter1\hdr.adf test.fit
> My version of
> GDAL is from Feb-15-03.
> Any ideas on this?
> Thanks,
> Jim Julian
> julian at preferred.com
> Gdal-dev mailing list
> Gdal-dev at remotesensing.org
> http://remotesensing.org/mailman/listinfo/gdal-dev
