[Gdal-dev] Image Reprojection
Matt Lynch matt at terraEngine.com
Mon Apr 7 12:32:12 EDT 2003
Hi Frank,
That did the trick!  Over the next few days I will work on a usage
tutorial for gdalwarp and submit.  That way you don't have to answer the
same questions repetively.
Thanks again,
Matt
-----Original Message-----
[mailto:gdal-dev-admin at remotesensing.org] On Behalf Of Frank Warmerdam
Sent: Saturday, April 05, 2003 1:41 AM
To: gdal-dev at remotesensing.org
Subject: Re: [Gdal-dev] Image Reprojection
Matt Lynch wrote:
> Hi Frank,
> I have succeed in reprojecting an image that was in UTM to latlon now.
> An error message still appears, however the reprojected image appears
> to match up correctly.
> C:\gdal>gdalwarp -t_srs "+proj=latlong +datum=WGS84"
> 002026_0100_000703_l7_08_ utm21.tif memTest.tif
> ERROR 1: Can't find requested entry point: pj_strerrno
> Creating output file is that 18397P x 11549L.
> :0...10...20...30...40...50...60...70...80...90...100 - done.
> I still have some questions:
> 1.  How do I fix the error message, and is it significant?
Matt,
The error is not significant.  Upgrading to a very recent PROJ.4 (such
as 4.4.6 or 4.4.7) should resolve the message.
> 2.  How can I specify a 10TM (see below for spec)?
I think:
+proj=tmerc +lon_0=-115 +k_0=0.9992 +x_0=500000 +datum=NAD27
(or change +datum=NAD27 to +ellps=clrk66 if you have problems.  Older
PROJ.4 libraries don't support datums).
> 3.  What are the memory limits (the image used was 197M)? (you had
> mentioned one reason to use gdalwarptest would remove memory
> restrictions)
The gdalwarp program will attempt to hold the entire source and
destination image in memory.  The gdalwarptest does the image in chunks
to limit memory use.
> 10TM spec
> datum = Nad27
> central meridan = -115
> scale factor = 0.9992
> lat of origin = 0
> false E = 500,000
> false N = 0
Good luck,
I set the clouds in motion - turn up   | Frank Warmerdam,
warmerdam at pobox.com
Gdal-dev mailing list
Gdal-dev at remotesensing.org
http://remotesensing.org/mailman/listinfo/gdal-dev
Incoming mail is certified Virus Free.
Checked by AVG anti-virus system (http://www.grisoft.com).
Version: 6.0.467 / Virus Database: 266 - Release Date: 4/1/2003
Outgoing mail is certified Virus Free.
