[Gdal-dev] gdalwarp: bad output header?
Sat Apr 12 21:53:37 EDT 2003
Michael Tan wrote:
> Hello Frank-
> The files are from OpenEV_FW_154.zip
Michael,
OK, I am pretty sure this is related to a specific bug in the GeoTIFF
driver from around that time.  It is fixed in CVS now.  If you can easily
build from source, then grab the current source from CVS and rebuild.
Otherwise I will try to crank out a 1.5.5 release of the utilities in the
near future.
Best regards,
