[Gdal-dev] jpeglib.h not found
Jack Twilley jmt at twilley.org
Tue Apr 29 11:53:04 EDT 2003
>>>>> "Frank" == Frank Warmerdam <warmerdam at pobox.com> writes:
Frank> Jack,
Frank> I have committed a fix to frmts/gtiff/libtiff/GNUmakefile to
Frank> look like this:
Frank> ifeq ($(JPEG_SETTING),internal) ALL_C_FLAGS := $(ALL_C_FLAGS)
Frank> -I../../jpeg/libjpeg endif
Frank> Instead of:
Frank> -I../../jpeg endif
Frank> I hadn't encountered this problem before because I have jpeg
Frank> include files littered through my system.
The file frmts/jpeg/jpgdataset.cpp also has the same issue, so you'll
probably want to fix frmts/jpeg/GNUmakefile the same way.
Frank> Best regards,
Jack.
Jack Twilley
jmt at twilley dot org
http colon slash slash www dot twilley dot org slash tilde jmt slash
Name: not available
Desc: not available
Url : http://lists.osgeo.org/pipermail/gdal-dev/attachments/20030429/c7a5d771/attachment.bin
