[Gdal-dev] jpeglib.h not found
Tue Apr 29 15:22:06 EDT 2003
Jack Twilley wrote:
> The file frmts/jpeg/jpgdataset.cpp also has the same issue, so you'll
> probably want to fix frmts/jpeg/GNUmakefile the same way.
Jack,
Thanks ... I have fixed this too.  I could have sworn I fixed this when
Assefa reorganized the libjpeg a bit, but apparently I didn't.
Best regards,
