[Gdal-dev] proj4
Xiaodong Zhang zhang at aero.und.edu
Wed Apr 30 18:50:29 EDT 2003
Hi Frank,
The Proj.4 has been installed and its library libproj.so is in the
searching path defined by LD_LIBRARY_PATH. What else could be wrong.
Xiaodong
Frank Warmerdam wrote:
> Xiaodong Zhang wrote:
>> Hi,
>> I just found out that the gdal I'm using is not linked to Proj4 and I
>> can not find any definition in the GDAL configure file. How can I
>> link them together? Thanks.
> Xiaodong,
> Normally GDAL isn't directly linked to PROJ.4, it loads the PROJ.4
> DLL/.so at runtime.  Just build and install PROJ.4 on your system and
> hopefully it should just work.
> This might be a good one for the FAQ!
> Best regards,
