[Gdal-dev] gdal_merge.py question
Gillian Walter gillian.walter at atlantis-scientific.com
Fri Aug 8 14:21:59 EDT 2003
You'll need to set some environment variables (PATH,PYTHONPATH,
PYTHONHOME,OPENEVHOME).  If you look at openev.bat in openev's bin
directory, you should see these settings.  I think gdal11.dll is in
OpenEV's bin directory, so adding the full path of the bin directory to
the PATH variable (and if that fails, to the PYTHONPATH variable) should
hopefully fix things.
-Gillian
Stephen H. Savage wrote:
>Greetings,
>I've recently installed the curreent version of OpenEV.  I'm trying to execute
>the command "gdal_merge.py -n 0 -o out.tif in1.tif in2.tif" and I get an error
>message that reads "The application has failed because gdal11.dll was not
>found..."
>What do I need to do to make sure gdal utilities see all the .dlls and the like?
>Thanks,
>-Steve
>Stephen H. Savage, Ph.D.
>Department of Anthropology
>Box 872402
>Arizona State University
>Tempe, AZ  85287-2402
>shsavage at asu.edu
>http://archaeology.asu.edu/Jordan/index.html
>_______________________________________________
>Gdal-dev mailing list
>Gdal-dev at remotesensing.org
>http://remotesensing.org/mailman/listinfo/gdal-dev
